跳转到主内容
Repair guides and troubleshooting for the Acer Aspire V5, a series of laptops on the Windows OS by Acer.
132 个问题 查看全部
Access to ACER ASPIRE V5 471 Bios , want to change win
Unfortunatly i have acer aspire v5 471p , and want to change window 8.1 to win10
No Access to ACER ASPIRE V5 471p Bios
But there is no BOOT menu option or setup option ,
I have tried f2,f8, f10 and f12 neither have worked.
No key is workinG to booT it, plz help me .
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Is there any one ???
完成的
try delete when booting . spam the daylights out of on startup
完成的
disable the secure boot and fast boot look for csm in boot menu disable it be sure your os flasdrive is inerted then save and exit . note press Esc to display bios
完成的
添加一条评论
4个答案
已选择的解决方案
Hi,
To access BIOS in Win 8.1(or Win 10) turn off fast startup mode then shutdown the laptop, (do not select restart this one time). On starting again you should be able to access BIOS in the normal manner.
Here is a link which shows you how
http://ccm.net/faq/31793-windows-8-1-how...
这个答案有帮助吗?
得分 3
2条评论:
Nope still it is not working :(
完成的
I turnoff fast startup mode , but again it is not booting with any key and also not showing the setup , which comes in start
完成的
添加一条评论
Hi,
Have you tried this?
http://acer-au.custhelp.com/app/answers/...
这个答案有帮助吗?
得分 3
添加一条评论
No . Still it is not working
这个答案有帮助吗?
得分 0
添加一条评论
Go to the system BIOS via the advanced startup and change the boot priority order putting usb at the top and change boot type to Legacy then reboot and press F12 and run dban or windows 10 or whatever
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
NoBody 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 13
总计 30,110
