跳转到主内容
第三代 Surface Pro 平板,发布于2014年6月20日。
Is there a way to replace a faulty USB port?
My USB port has stopped working.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
最有帮助的答案
Tal Ben Ami,
Sorry to say that surface pro 3 is hard to open to do the repairs. Good news is USB port replaceable easily because of surface pro3 comes with full size USB port. if the USB connector internally damaged you can replace it. if you cannot find damages on it check the 5V DC power rails + USB fuse before replacing the USB port. This guid will help you to teardown surface P3, use hot air around 200C air 20 (Hakko) to heat the glued canners and it will help you to open the device without damages.
Cheers!
这个答案有帮助吗?
得分 3
添加一条评论
Where can I buy a replacement USB socket for the Surface Pro3?
这个答案有帮助吗?
得分 1
1条评论:
Me too! My investigation days it is difficult risky repair.
完成的
添加一条评论
Hi, i have one surface pro 4, but the usb port 3 dont work any more, its possible replace?
How much does it cost?
If I were to fix it, I'd be interested if you can fix the flicker screen, a line pops up sometimes down, it's not something disturbing, but if I fix it, I'd fix it completely.
Is it still worth fixing?
I thought, maybe usb port 3, changed to micro usb 3.1 type-C, why not?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tal Ben Ami 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 7,910
