跳转到主内容
The HP Officejet 6500 is a color All-In-One printer. Released in 2003. Model number: CB815A#B1H.
52 个问题 查看全部
Paper will not feeding
Cleaned all paper feed rollers.
Pick-up rollers not picking up the paper
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
3个答案
已选择的解决方案
Hi,
This link may be of interest to you. Scroll down to the post by 'jambro' (6th one down) for a description of a possible fix
http://h30434.www3.hp.com/t5/Scanning-Fa...
这个答案有帮助吗?
得分 4
添加一条评论
The typical problem is associated with the cog sliding out of position along the drive shaft. This cog can be viewed by placing a mirror (facing upward) just within, and to the right, of the paper feed tray to view the drive shaft (running right to left) above the compartment. Also, use a flashlight to illuminate the area clearly. You will note a plastic cog (geared wheel) positioned on the shaft. When properly set, this should be positioned on the splines located on the right side of the shaft, which would align it to the gear that operates the paper feed rollers. It is not uncommon for this cog to dislodge from the splines and slide toward the left. Simply slide it back (right) over the splines until it is perfectly centered to drive the paper feed gear.
Equally common is that the corresponding splines on (within) the cog may become slightly worn (unit is entirely plastic after all), which allowed it to become dislodged in the first place. To ensure it remains in place, most DIY's apply a thin application of Super Glue to the splines on the drive shaft, then slide the cog into place - ensuring its gears are perfectly married (positioned) to/within the gears that drive the paper feeder. Allow ample time to "completely" dry before testing the printer.
Hope this solves your problem.
这个答案有帮助吗?
得分 4
1条评论:
Thank you. I made a small hole in the bottom of the paper tray so I could work on it.
完成的
添加一条评论
20 Oct 2019: Problem was the little cog as explained above. It now works fine. Such a simple fix. Thank you genewcollins.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Roche 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 29
过去 30 天: 50
总计 8,283
