network operator doesn't stay set
After every phone call I make, my network operator gets changed and it says that I'm not registered on a network. I have to turn off wifi, click on network operators, search for one and then register. I can then turn wifi and wifi calling back on and call one more call before I have to start the procedure all over. Is there anyway to fix it permanently?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
What carrier are you using? Also, is your network operator set to Automatic?
完成的
Yes it is set to automatic and I use metropcs. They've reset the phone several times which takes 30+ minutes and erases all my saved voicemail.
完成的
添加一条评论
