跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
TouchID not working even after replacing metal plate. Error 53 solved
After replacing display I used to get error 53 which is resolved by replacing metal plate (ribbon). Even after solving ribbon issue and using original home button and parts my touch id is not sensing my finger print. When I go to add finger print in settings it does nothing. Doesn't sense my finger.
Already tried dusting off the contacts thoroughly but no avail.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Have you tried factory restoring the device with the original home button? (this could be very risky if the button is damaged or it is not connecting properly.) Are there any signs of water damage in the device? Also how do all the connections look inside? Have you tried cleaning the connections with a ESD safe brush?
这个答案有帮助吗?
得分 0
2条评论:
No water damages at all. Cleaned connectors with soft tooth brush.
Will try factory reset later today and hope that fixes it.
完成的
Did factory reset but touch id is not sensing my finger .
完成的
添加一条评论
添加你的答案
Chet Patel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 180
