跳转到主内容
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 个问题 查看全部
Screen not staying on
iPad mini a1490, glass and LCD both repaired. When I try to turn the iPad on, the Apple logo comes on, then it goes to a black screen. I let the battery run down and plugged it in. The charging indicator comes on for a second then it goes to a black screen. It's like the screen is shorting out..... Help please
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Same issue & model! But my device has never been repaired, it stays powered, I hear the sound when I plug in power, and if it is dark enough I can see that the backlighting is on. On occasion, especially if the device is cool, the screen and touch respond well enough, but as soon as it warms up the screen goes black. I can turn off the device if I'm lucky and swipe in the correct area. What needs to be repaired and is it even worth it?
完成的
添加一条评论
1个答案
Is the device staying powered on? Do you hear any lock sounds or notice any activity when the screen goes black? Does the device boot loop or just turn black?
If the device is boot looping you may have damaged the gas gauge components that are next to the battery connector when using your tool to disconnect it.
Let me know what you find!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
marchinds 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 138
