跳转到主内容
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
271 个问题 查看全部
What is the model info for the gyrometer/accelerometer in note 5?
Hi. My gyrometer/accelerometer in my Verizon note 5 stopped working...I tried factory resetting,dialing *#0*# and nothing pops up, and also calibrating it. It seems like the sensor is off or unresponsive. I am not able to rotate the screen, take pictures, watch videos in landscape Is it an easy repair to replace it? Is it modular? And what is the model information for the sensors used? Any help would be appreciated. Thanks in advance.
Dan
P.s. I apologize for the messy post. It is my first post.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
1.The first recommendation is to do "hard reset"
2.An effective method to check if the phone’s gyroscope or accelerometer is functioning by doing a self-test. This will help to see what the real issue is when the Samsung Note 5 screen won’t rotate. You can do this by pressing the code “*#0*#” (without the quotation marks) on the Samsung Note 5 dial pad. Once you are in the service mode screen, tap on “sensors” and do a self test. f your wireless carrier disabled the option to access the service screen, then your only recourse here is to reset the phone to its factory defaults.
3.Another out-of-the-box tip from some is to hit the Samsung Note 5 with the back of your hand to give your phone a gentle jolt. If you want to take the risk, you may want to do that, just be careful.
这个答案有帮助吗?
得分 1
2条评论:
I tried it all. and it doesn't work...
Is there any thing you could recommend?
完成的
Im in the same boat with my note 5 can part be replaced
完成的
添加一条评论
添加你的答案
Daniel L 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 1,672
