跳转到主内容
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
backup from android system recovery
Hi
my Samsung note 2 unable to boot pass the Samsung Logo from start and i will need to do a factory reset. How can i backup all my files in the phone before i factory reset it?
thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You should firstly check if the physical buttons are responding properly, especially the volume buttons to get rid of the Android recovery mode.
If the problem still exists, try the following steps:
Step 1: Power off your Samsung Note 2. Take out the battery. And then reinsert the battery after a few seconds.
Step 2: Press and hold the Home button, Power button and the Volume up key simultaneously until your device vibrates.
Step 3: Release the Power button but continue to hold down the Home and Volume up key to navigate to the Android recovery screen.
Step 4: Press the Volume down key to reach the "Wipe Data/ Factory Reset" option and then press the Power button to select it.
Step 5: Press the Volume down key to highlight "Delete All User data" and then press the Power down to select it.
Step 6: Your device will reset and display "Reboot System Now". Now, press the Power button to reboot your phone in normal mode.
To make things easy, third-party program is grealy recommended. MiniTool Mobile Recovery can help you solve the problem easily.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 213
