跳转到主内容
加入维修社区 - 创建账户
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
Mac Mini Won't Start
I started my Mac Mini yesterday for the first time in a few years. It started up like a trooper. Then it just turned off and now I can't get the light to come on.
Tried to unplug for 20 seconds, plugged it in, then waited five seconds, but still no luck.
I will be going to the apple store to talk to a genius. Maybe it's just the power supply, hopefully that is it.
Anyone else have these symptoms and find an answer?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Apple no longer supports this model. While the genius with be sympathetic on your plight he won't be able to help you.
When you try starting the system do you get any signs of life? Like fan noise or LED flashing?
这个答案有帮助吗?
得分 0
2条评论:
There is no sign of life. No LED. No fan noise. I was hoping to try a different power supply and thought genius might have one.
完成的
Apple won't have the needed power adapter. I would look at eBay for a unit and make sure I could return it if it didn't work. Remember this model can't run the newer OS's
完成的
添加一条评论
I am having a problem with my Mac Mini, there’s no display but i got an apple icon with a full bar under but it just hang there. I still chimes whenever I reset the PRAM. Please help!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kenneth Sayers 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 791
