跳转到主内容
Also known as the Moto G3—an Android smartphone released by Motorola in July 2015. It serves as an economical alternative to Motorola's flagship phones. Model XT1540 in the US, with dual-sim and "Turbo Edition" variants sold in other regions.
Replacement LCD screen flickers
Hi
I have a nearly new Motorola Moto G 3rd Generation that I dropped and smashed the screen. It was fully functioning, but the front glass was shattered.
I bought a replacement screen / LCD / digitizer assembly from eBay and installed it. Initially, the screen appeared OK, but then started flickering at about 2 - 3 Hz. The screen appeared dull, but that is probably due to the flickering. It now consistently flickers, though is OK for a second or so on power up.
I performed a factory reset, but that didn't fix it.
I contacted the seller, who recommended I clean the contacts and try to seat the screen cable again. I've tried this a few times but it hasn't improved things.
Is this a defective screen? Note: I didn't disconnect the battery before replacing, because you can't get to the battery.
Many thanks
Mooncat
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Did you find a solution I have the same problem! Thanks
完成的
添加一条评论
1个答案
If you did your replacement correctly (and it sounds like you did) and you have already cleaned the contacts and reseated the cable several times, it does sound like a display gone bad. Hopefully the eBay seller gave some sort of warranty on it. Otherwise you need to pick up another display and make surfeit has at least a 30 day warranty (that starts the day you receive it, not the day the send it, in case of longer shipping time, like if getting from China or Hong Kong).
Cheers!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Simon Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 1,368
