跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 个问题 查看全部
Is it possible to replace the battery connector on the logic board
MBA 2013 13 inch
The connector in question is the one marked 358MA. I've tried searching for a replacement connector but as you can tell I have been unsuccessful.
I'm currently using my Mac with just the power cable.
Update (02/11/2016)
The connector of the battery was cut off and the wires stripped back to align with the solder pads on the logic board. The battery cable was then soldered to the pads of the logic board. Keep in mind the surface mounted connector of the logic board came loose which left the pads exposed.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
5条评论
How do you attach it. Can it just be glued in?
完成的
You solder it in. @Lisa Mac
完成的
In my attempts to do this same repair, I lifted the centre pad off the board. The clean up was a bit messy and I don’t know if it was my doing or by design, but pads 1-2-3 have continuity between all three and same for 7-8-9. 4 & 6 are isolated and still work and #5 pad is gone. Anyone have a schematic of what I should see in testing the pads? Is it okay to bridge 4&6?
完成的
As Aiden has said the fix requires soldering. From the research I have done (2019) the task requires someone with developed soldering skills.
Battery connector broken off motherboard
完成的
添加一条评论
2个答案
已选择的解决方案
I had my technician at work hard wire the battery to the board. She cut the connector off the battery, stripped the wire back and soldered it in place. It was done under her microscope. I have to warn you that my issues came about because water was spilled on MRI my mac which damaged the original battery. I got a used one from eBay and tried to solder myself but over heated the connector on the logic board that damaged it. The used battery stopped working recently so I had the technician pull it out and soldered a second used battery on. So far no issues yet.
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
Well seeing that I have access to a lab that does repair of PCB I asked the technician to remove the female connector from the battery and hard wire it to the board until I can find another 358 MA connector. The battery is charging and all looks well for now. I'm hoping I can find a connector soon.
这个答案有帮助吗?
得分 3
7条评论:
It's now late May and my Mac is still going strong with no issues.
完成的
Hello, I have the same problem, the connector has broken me, could you explain better how you solved it?
Thank you
a greeting
完成的
Hi.
Is there someone who knows where to order the connector you talk about ?
358 MA (S9B-ZR-SM4A-TF was the wrong one, right ? )
完成的
Connector S9B-ZR-SM4A-TF is compatible.
完成的
Thanks Paul, I will order it and have it mounted.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Edwin Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 18
过去 30 天: 71
总计 10,169
