跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
iPhone 4S Digitizer Problem after Screen Replacement
I just installed the new screen on my iPhone 4S.
I followed the instructions perfectly and was very careful.
After installing the screen everything worked ok except the lower bottom of the screen is unresponsive to gestures.
It is a small part of the screen but it is very frustrating (I can't open the slide up menu, access the numbers on the keyboard, etc)
Is it possible I caused this or is it most likely the digitizer's fault ?
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi John
I think is faulty part you have installed. If you could get hold of another one and refit it may solve the problem.
Hope this help
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John Z 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 86
