跳转到主内容
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
237 个问题 查看全部
Microphone not working after charging port replacement
Hello,
I have changed the microphone / charging port on my S6 Edge. Now the microphone is very fuzzy and people can barely hear me when i'm talking over the phone. Everything else is working fine. The repair went smoothly as I've fixed quite a few of these before.
Has anyone else had this problem? I'm guessing it could be different rev. numbers on the part. Although I binned the old one and cant find out which version it was.
Any help will be greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
So you've taken apart a few of these? Where did you order replacement adhesive from?
完成的
添加一条评论
4个答案
已选择的解决方案
If it's not OEM, it's common for the replacement headphone ports/mic to be bad.
Just get another replacement, chances are it will be better.
这个答案有帮助吗?
得分 3
1条评论:
I'll give that a go and let yous know. Thanks for the quick reply.
完成的
添加一条评论
OK so after trying 2 different charging ports / microphones. The problem was still there. I tried one more from another supplier and it worked fine. Seems like there are quite a few faulty ones going around. Thanks again
这个答案有帮助吗?
得分 0
1条评论:
Can you please help me, my s6 edge plus stops working the mic, what flex cable should i buy? regards
完成的
添加一条评论
Hey did you ever fix your mic issue. I have used the earrings ...no good factory reset.. No good... Took Sim out and no good.. Ugh help me somebody please
这个答案有帮助吗?
得分 0
1条评论:
Yes, he did.
"OK so after trying 2 different charging ports / microphones. The problem was still there. I tried one more from another supplier and it worked fine. Seems like there are quite a few faulty ones going around. Thanks again"
完成的
添加一条评论
The same problem so after trying 4 different charging ports / microphones. The problem was still there.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Peter N 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 20
总计 4,188
