跳转到主内容
A 4 Amp corded power drill released in June 2014 by Black and Decker. The corded device is a part of the Matrix Quick Connect System which enables various attachments.
How can I switch the direction on the drill?
I need to unscrew a misplaced screw but I don't know how to switch it into a reverse position.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
please tell me how the reverse mechanism works in bosch gsw 450re , because it isnt working in my machine ..
完成的
How to take a screw put w/ a 1/4in single speed drill by black &decker
完成的
添加一条评论
2个答案
已选择的解决方案
In order to change the direction of torque, fully toggle the switch above the trigger into the alternative position.
这个答案有帮助吗?
得分 3
1条评论:
Hi does a black and decker bd163va have reverse.or what is the black round button for near trigger
完成的
添加一条评论
I have a domestic 450w Black & Decker electric drill that does not have a reverse switch, yet it is turning anti-clockwise. Mind you, I lent this driller to someone who returned it long ago, but now I wished to use it in lieu of the other two that I have and discovered that it has started to turn anti-clocwise with the result that the chuck unwinds. Please can i repair it as it is adequate for me.
Update (02/09/2017)
I do not know if he repaired it or not, because he passed away.
Update (02/09/2017)
Re Black & Decker drill, it only has a common switch and a sideway button which when pressed while drill is functioning will render drill functioning automatically. Again, please anyone with a correct answer? Thanks beforehand.
Update (02/09/2017)
Hi Mr Edgardo Gutierrez thank you for your answer. But my drill has a common switch.
这个答案有帮助吗?
得分 0
1条评论:
It is possible to change the direction by reversing the brush connection which will be internal to the machine. Need electrical knowledge to do so.
完成的
添加一条评论
添加你的答案
Tyler Yurina 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 51
总计 49,582
