The iRobot Roomba 560, an automated vacuum cleaner, was released in 2009.
11 个问题 查看全部
Access to Roomba 560 circuit board.
I have a faulty Roomba 560. afer substitution teting I gather the problem is in the board.
I suspect the problem may be in some capacitor as the problem is intermitent but recurring.
simple screw driver dismantling left me short of the pcb.
Where can I find instructions to access the pcb?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 1
评论:
Did you try to find solution from irobot customer care? I think you should not fix roomba by yourself, it's still a high tech machine anyway
Oh, try to find answers form other sites like http://irobotroombareviews.com/ I've just catched it last week and it's quite useful
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
3个回答
已选择的解决方案
Hi, Here's a link to the service manual. Hope it helps.
http://choisirsonaspirateur.info/wp-cont...
这个答案有帮助吗?
按维修分数 3
评论:
+ research
Thanks, most useful info
添加一条评论
最有帮助的答案
I had a similar problem, but had to replace some sensors on the board. Looked all over for a fix. Found an affordable one that worked well. took an hour or so.
http://eesolutions.ca/roomba_repair_kit....
I'd recommend it. Took forever to find the site though.
这个答案有帮助吗?
按维修分数 5
添加一条评论
Hi.
Here is quick fix for your roomba.
http://www.abstractpath.com/2008/fixing-...
Cheers
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Axel Brinck 将永远感激不已
浏览统计数据:
过去的24小时: 3
过去的7天: 11
过去的30天: 39
总计 12,310
