跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
iPhone will not turn off.
I just replaced the front glass and everything works fine but the phone will not turn off or reset.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
You did not seat the power button flex properly or you damaged it.
这个答案有帮助吗?
得分 1
1条评论:
I went back in right after I posted the question and found that I had not seated the power cable. All is good. Thanks for your reply
完成的
添加一条评论
Along the lines of Jake's thinking, it could be you left the power flex under the logic board. Open up the iPhone and check your work. The power button flex cable connector is possibly under the logic board. If so, carefully take the iPhone apart and lift the logic board so it can be routed on top of the logic board and connected properly.
这个答案有帮助吗?
得分 1
1条评论:
Brad, thanks, I went back in right after I posted the question and found the power cable under the logic board. All is working now.
完成的
添加一条评论
添加你的答案
Walter Davidson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 83
