跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
I accidentally dumped Koolaid on my phone
Hi! Okay so earlier today I was chilling, watching netflix, stuff like that and decided to get some kool aid, so I did. I got back to my bedroom and accidentally spilled some of it onto my phone. It's on, but I can't seem to unlock it (I'm assuming the screen was damaged?) and it keeps randomly bringing up the option to turn off my phone. Please help (this happened about an hour and a half ago as of right now).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I would turn it off because odds are there's still moisture in the device. Sounds like you spilled near the power button where the flex cable for your screen is, so you may have damaged one or both screen and power button. I'd dry it out completely (Damp-rid works better than rice) if you have the ability to open it do so and disconnect the battery then let it dry 100% before trying again. If it's an iPhone 4 replacing it with a 4S or 5 would be almost the same cost as fixing it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Maeve Nguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 9
总计 290
