跳转到主内容
Repair guides and support for Apex.
35 个问题 查看全部
How do I get my camera to take pictures front loading
when I open the camera it will only take pictures in reverse. I cannot figure out how to take a picture of someone standing in front of me.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
3个答案
已选择的解决方案
HI,
You don't say the model number of your tablet. A lot of tablets only have one camera which is usually facing the user, (used for when you "Skype', video call or take selfies - like an inbuilt webcam on a laptop). You should be able to locate it by turning on the camera app and then seeing where it is, by looking at the angle of the picture of yourself. Once you have found what the lens looks like if your tablet has two cameras there should be a similar lens to be seen on the back (non screen side) of the tablet.
If you cannot find it, unfortunately your tablet has only the one camera (check your User Guide to be sure) and the only way to take pictures of what is in front of you is to turn the tablet around and hope that you get the correct picture 'in the frame',
If you do have a second camera there should be an option in the camera app settings to select the front or rear camera.
这个答案有帮助吗?
得分 4
添加一条评论
Make my camera take front loading pictures
这个答案有帮助吗?
得分 3
添加一条评论
I cant take a front loading pics only back camera works
这个答案有帮助吗?
得分 2
2条评论:
Hi,
What is the make and model number of your tablet?
完成的
Galaxy 7 Samsung phone
完成的
添加一条评论
添加你的答案
Tammy Davidson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 13
总计 3,684
