跳转到主内容
加入维修社区 - 创建账户
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Half of screen doesn't work after screen replacement
Hello Everyone,
I cracked the screen on my iPad mini and tried fixing it myself. I first tried replacing only the glass screen, and the right side wasn't working when I try touching it, which is where the crack was on the old screen. So I figured maybe the LCD screen doesn't work, so I just replaced that too, and the right side doesn't work still. It shows all the apps and stuff, but gives no touch response. Anyone know why it would do this? I followed step by step instructions perfectly to try and get it right. Could it be a bad digitizer, or would this happen if it got bent at all maybe? Any help is appreciated. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
I had same problem. My screen came with digitizer attached. 2 screen/digitizer conbos later same issue.
完成的
添加一条评论
3个答案
最有帮助的答案
Honestly i'm 99.9% confident it is a bad digitizer. You should not have had to replace your lcd though because that has nothing to do with your "touch response." Hopefully you can get a refund, if you need more consulting you may check this out. https://goo.gl/D8uvtn
这个答案有帮助吗?
得分 1
1条评论:
I'll have to get a new digitizer then. Probably can't get a refund on LCD, but I can probably re-sell it on eBay for close to full value
完成的
添加一条评论
You didn't need a new LCD as long as the LCD displays an image it's fine. The problem is your digitizer, the digitizer can be lifted or tipped up from the frame of the iPad and the touch screen will still work. Also make sure your using kapton tape on the bottom of the screen, or you will have ghost touching. Most important with the iPad mini is don't use a cheap screen with silver edges it should have cooper!
这个答案有帮助吗?
得分 0
2条评论:
I'll get a new digitizer that comes with the tape/adhesive on it.
完成的
I always remove the adhesive that comes with the screens, they don't hold the screen down properly, and you will end up with the screen lifting off. Peel that stuff off and buy some adhesive from bowler Tech adhesive, the stuff is precut and applies to the frame, never had a screen lift using this product, costs about $6
完成的
添加一条评论
I'd go with bad digitizer. However, look in the digitizer socket on the board to make sure no pins were pulled out of the socket as this does happen sometimes.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Geoffrey Goldman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 47
总计 15,627
