跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 个问题 查看全部
Mac not charging after minor water damage
Hi guys.
I've got a friend's mac that got given to me to have a look at. The mac at first was not starting up at all after a water spill.
The laptop was then disassembled and thoroughly cleaned with alcohol to ensure there was not water residue left on the logic board.
I replaced the battery, and the DC jack. After replacing the battery the macbook started up without any problems.
My only problem is that, after trying 3 separate chargers (known to be working on other macs) the light on neither chargers will light up!
I don't have ANY colour light showing. Any one able to point me to what chip might needing to be replaced (if any) or if there's any tricks with the macbook chargers? I'm not too savvy with macs I repair windows laptops mainly.
I've cleaned the logic board about 3 times now without ANY sign of corrosion at all. Every chip looks to be fine (well as far as what my eyes can see).
Looking forward to a reply, peace.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Trying to tell you exactly what chip needing replacing is toooo vast! It could be the chip, resistors ,caps or inductors or even shorted traces that require jumps. You need to search the net for boardview and schematic for your board and check for short to ground with multimeter youtube can help if you look right. No light on the magsafe usually means the one wire over voltage is not working , feel around on the board and see also if there is area that is super super hot obviously this means the circuit is shorted. That's all I can do this is a very simple answer to a very in depth answer. Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
sxcchaldo69 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 118
