跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Will not slide to unlock
When I try to slide to set up my iPhone 5s it doesn't respond. I've done the hard reset and nothing works. It also says hello in the center of the screen and where it says 'hello' and 'slide to set up' it keeps changing to different languages. Please help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
I'm assuming you've waited for a while - sometimes they won't respond for a 30-60seconds or so after booting. If so, the digitizer is not working on the display. It could be a faulty display, but often it's just that it got disconnected. Follow these instructions steps 1-15. Notice the last thing you disconnected was the digitizer. Check the cables and connectors for dirt or pieces of glass or similar that could sit inside and keep the connector from fully seating - clean it out with air and/or alcohol swabs. Then click the cables back on the connectors in the reverse order of steps 13-15. You can now turn the phone back on and see if it's working. If it is working, make sure you have some not-conductive spacer on the back of the connector before you reassemble (see the foam in the pictures above - that puts pressure on the cable to keep it from popping off, and replacement screens often don't have it).
If it still isn't working you have either a faulty screen or a more serious problem on the logic board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Wes Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 165
