跳转到主内容
华为 荣耀 4x 维修支持指南
18 个问题 查看全部
Why it always show no service?
My Honor 4x always show No service. I alreadr checked with different companys sim, but the problemm is still same. Showing no service. Please help me to resolve this issue.
[Email Redacted]
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
10条评论
Hi,
1.Has the phone ever worked using a SIM card? 2. Does it say no signal or no SIM card found? 3. Have you tried to factory reset the phone?
完成的
hi my honor 4x shows no service...center said network IC problem..u have to change motherboard costing 8000 rupees...is any other way to repair Network IC or motherboard...8k is big amt nowdays u get phone in 8-10k...pls advice
完成的
I also having the same problem. Pl's tell service advisor's to recover my mobile from this problem
完成的
same problem i also having trouble after changing my honor holly 2 plus
完成的
I also have the same problem. My Huawei honor 4x can't detect my simcard. I already tried a lot a sim but still the same. Have the sim icon on the top with exclamation point. Will you please help me with this ?
完成的
显示更多的5条评论
添加一条评论
3个答案
最有帮助的答案
Yes previously it was working fine, but once its display and touch had broken due to feldown. So I changed the screen. But after changing the display network is not coming. Shopkeeper said its software problem. I have to go to service centre.
这个答案有帮助吗?
得分 1
添加一条评论
Maybe the sim tray broken
这个答案有帮助吗?
得分 0
1条评论:
what is cost of a sim tray
完成的
添加一条评论
Signal Strength ? then network manual
Update (03/18/2016)
try to imei change then try network show
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ashish kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 14
总计 14,422
