跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Why is the connection on my new battery larger than the original?
I ordered a new battery for my IPhone 4S. The connector is slightly larger than the original (20/1000's wider) and won't plug in. Upon closer examination, the APN on the new battery is 616-0580, the old one is 616-0582. Did I receive the wrong battery?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Both of those APN are correct for iPhone 4S. The connector on the new battery should be exactly like the connector on the old one. If the connector is different you got a fake or mislabeled battery.
这个答案有帮助吗?
得分 2
1条评论:
Thank you for your quick response, it was most helpful.
完成的
添加一条评论
添加你的答案
Deb Crosby 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 67
