跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
577 个问题 查看全部
which part to replace for rotation problem?
Hey guys, got a pad in that wont rotate, rotate has been unlocked and all settings have been reset but the screen just will not rotate.
Which part holds the orientation device on it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Are you trying a Hard reboot : Home and power in the same time ?
这个答案有帮助吗?
得分 0
2条评论:
yeah ive soft reset, are you saying try disconnecting battery and resettuig it that way?
完成的
No, only press home and power at the same time
完成的
添加一条评论
I have a similar problem too, but on an iPad Air 2. It is stuck in landscape and will not rotate, even after hard rebooting the device. The customer said he already tried resetting it as well. Any idea which part needs to be replaced?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lewis 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 99
