跳转到主内容
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
Inserting Home button cable in socket
All the guides just assume that once you get the device apart that you can reverse the instructions and get it back together again. On the Ipad 4, I have found getting the home button cable back into it's connector to be anything but easy. In my case, I can only get the cable around halfway into the connector before it starts to bend/tear. I do have a spare as the home button assembly was not damaged on the old digitizer but I don't want to swap over to it until I have better grasp on how to get it plugged in without damage? Any ideas on how to get the cable fully into the connector?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
It is definitely a pain in the ass.
if you're installing a digitizer with the home button flex already installed, it is much easier to take it off, plug it in to the connector, and then attach it to the digitizer. :-)
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
crusher171 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 187
