跳转到主内容
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
Screen is not as bright
I had to replace my complete screen ( touch digitizer and LCD screen).I. put it back together and it came on but noticed screen was not as bright even though brightness controlled all the way up.If I put it on auto bright you can barely seen the screen. I doubled check the LCD ribbon and seem to be in good. Any ideas on what could be the problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Not sure who you got your screen from but sometimes there's a protective film on the screen that's tinted you need to peel off. Ive made that mistake once myself.
这个答案有帮助吗?
得分 1
3条评论:
No I removed that
完成的
My screeen became dim after I upgraded to 10.1
完成的
@rouadi1 In your case I would check my settings in power settings and in the display settings. Sometimes upgrades change default settings
完成的
添加一条评论
Its your front camera flex cable (there is proxy on it) and this proxy didnt recognize light propertly
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Arletta 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,661
