跳转到主内容
加入维修社区 - 创建账户
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Water Damage to Note 3
Will replacing the Mother Board fix my water damaged Note 3?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
It all depends on how badly the corrosion on the phone is. You can always use some isopropyl alcohol to remove the corrosion on the battery connectors and other parts that show sign of corrosion. This will usually do the trick for you and save you a lot of money. replacing the mother board might not always fix the phone because other components might have signs of corrosion. I have brought back 2 IPhones from water damage back to life. you can always do some searches on YouTube about how the whole process works.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
brentonaichroth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 189
