Nexus 5x screen showing colorful static
Reboot the phone and the display looks black.
Highlighting works after pressing the power button noise appears on the screen (see photo).
Phone is connected via USB to PC, flashing on the fastboot did not help. Disassembled, disconnect the connector and back append the display - without any changes.
Problem is sudden, the phone does not drop, charged by other chargers, it worked fine.
Have you done any work to the phone recently? Have you tried unplugging the battery for a few minutes?
由 Toupee Scalper 完成的
Yes malfunction before I worked with the phone was flashed TWRP / bootloader / root. After flashing the phone worked fine, I rebooted it a few times, such problems do not arise.
After a fault, I disassembled it, disconnect the battery, the display, the camera, board. A few minutes later I collected it, the problem remained.
由 Senya 完成的
Did you solve it? Just happened to me the same, but after a reboot
由 Martin Bogado 完成的
Yes I change display module
由 Senya 完成的
The display or even stuff from motherboard? I'll take it to repair
由 Martin Bogado 完成的
