跳转到主内容
PS3是索尼电脑娱乐推出的第三代家用电脑娱乐主机。2006年11月11日发布,取代上一代产品PS2。
My PS3's HDMI port isn't working
My PS3's HDMI port stopped working and I had to switch to the Component cables. It was working perfectly and one day it just stopped. The TV seems to be getting a blank signal since it doesn't say no signal. I've also tried switching the HDMI to another port on the TV
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Did broke the connector of the hdmi jack when you plug in the hdmi cable to the port?
it easy to break it since this is soldered on the motherboard like a power jack on the laptop motherboard.
完成的
Well i had the same problem and im still trying to fix mine to also i just tried everything :/
完成的
添加一条评论
3个答案
已选择的解决方案
Did you check with another HDMI cable? That would be my next move if I were you.
这个答案有帮助吗?
得分 3
1条评论:
完成的
添加一条评论
If it turns out that the cable is not the problem, you can try resetting your video card. Hold down the power button for about 15 seconds. It will turn on and then back off again, with a couple of beeps.
这个答案有帮助吗?
得分 1
1条评论:
I did this to get it to switch to component
完成的
添加一条评论
I have had my USB and HdMI ports serviced at a repair company called VideoGame911. They did it really fast. I had it back in less then a week.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jorge Fernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 19,597
