跳转到主内容
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
114 个问题 查看全部
Everything turns on car won't start?
I was jumping my truck off using my wife's 09 equinox when the truck started I was diconecting the jumper cables when smoke started coming from the wires on thCPU box on top of the battery the car shut off and will not start up everything comes on gauges radio etc. But car will not crank no click sounds nothing what is going on?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
If you had smoke coming from the ECM which sits on top of the battery you've toasted it and will probably need to replace it. To test it get a OBDII reader and see if it will read anything at all. If it does check for codes and go from there
完成的
Im having exactly the same problem.
完成的
添加一条评论
3个答案
最有帮助的答案
Check the START fuse (#15) and the CRNK relay (#55) in the underhood fuse block. Sometimes, when jumpstarting (which you should not do with these vehicles), the voltage can back into your starter circuit and blow the fuse or relay.
这个答案有帮助吗?
得分 2
1条评论:
Start with easy stuff when you're diagnosing a problem. Power, ground, fuses, etc... If you gauges and such are working, then don't get roped into thinking the pcm is bad. You may have had some wires that got hot and melted some plastic inside the cover.
Check the starter for 12V. Cross the two big lugs on the solenoid. If it cranks, then there is a problem in the START circuit.
Also check the diode in the fuse block.
完成的
添加一条评论
There is an internal ground in the brain box (ecu) above the battery. Run a ground wire from one of the holes in the corner of ECU to a good ground that is not too long a run of wire. I used 12ga wire with 5/16th eyelets. I used 1/4" x 1" bolt to attach from ECU to the bolt that holds the upper grill in place. It came out about 12" long. You can replace the ECU if you like and just use this as a test.
这个答案有帮助吗?
得分 0
添加一条评论
You fried the cpu and if you get the number off the cup and call a junk yard they can find you the right one for way cheaper then a new one and works just as
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Edwin roper 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 25
过去 30 天: 113
总计 27,023
