跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
No Ringer; Doesn't Turn off
I need help please! :(
My phone got wet... Didn't soak into a body of water though. water got spilled on it.
Now there's no ringer. When I press the + and - button, no ringer bars appear. Sometimes it works then after a few minutes, it wont work again.
Also, my phone no longer turns off. It just restarts even though I slide it off. Please please help. Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Most likely need new charging port with flex cable. First, clean the iPhone charging port very well with clean toothbrush and isopropyll alcohol, clean it very well. If still problem, then replace the charging port with flex cable, a single part which includes the lower mic and the connector to the home button flex cable.
这个答案有帮助吗?
得分 0
1条评论:
My phone's okay now! First, I tried cleaning the charging port and it worked for sometime; ringer bars appeared but after a few minutes it disappeared again. Then I tried putting it on rice grains and waited for 10 hours (my phone's still on cause it wont shut down) and now it's okay. Thank you!
完成的
添加一条评论
添加你的答案
Anna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 50
