跳转到主内容
mainboard dead or io dead?
dear sirs im check my air because is dead!
the magsafe led is off, i check with a voltimeter as you can see in the pictures below, and in the main board conector has 14,8 v.
is the io board broken or there is any component in the main board that can i check to determine the fault?
i clean the main board with 98% alcohol and remount all the components.
Many thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Facing the exact same issue as you with a 2013 model Air. No power received, strongly suspect the I/O board, but uncertain as to how to test it to the exclusion of a motherboard issue.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
antony 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 10
总计 360
