跳转到主内容
加入维修社区 - 创建账户
The Canon PowerShot G16 is a 12.1 Megapixel point and shoot camera made by Canon and released in 2013.
Why aren't my pictures transferring to my computer?
I am trying to transfer pictures over to my computer, but my camera and SD card are not showing up on my computer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
There are a few reasons pictures may not transfer to your computer. If you are trying to transfer the photos by directly plugging in the SD card, two possible reasons are
  • The SD card is not inserted properly in the SD card slot on your computer
  • The SD card contacts are dirty
If you are connecting the camera by a USB cable, two possible reasons the pictures are not transferring are
  • The USB cable is not properly connected
  • The connections are blocked by debris
Some solutions for the SD card problem are
  • Ensure the SD card is inserted properly. Depending on your reader a portion may still be exposed
  • Clean the SD card contacts by gentle cleaning them with a small amount of rubbing alcohol
  • If you feel that the problem is with the camera not reading the SD card, please refer to the troubleshooting guide
Some solutions for the USB cable problem are
  • Ensure the USB cable is plugged in the appropriate port on the camera and on your computer
  • Unplug the USB cable from the computer, and replug it in back into the computer
  • Check to make sure that there is no debris in the ports on the camera or computer and clean them out if necessary
这个答案有帮助吗?
得分 0
2条评论:
camera works fine - card transfers over to the photoshop wherever that is - but does not show for 2019. all other photo are there -
完成的
I think it is with the camershop I do not know who develops them on my computer but they come outperfect. They are just not listed for 2019 on my listing on m y computer...…..so therefore, I cannot add to an email???????
完成的
添加一条评论
添加你的答案
Jonathan Harger 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 5,725
