跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
iPhone 5s slowly charging and fast battery drain
Hi,
i got an iphone 5s which is charging very slow and fast battery drain.
It doesn't matter if the phone is in flight mode or not.
I think, it is an IC problem.
Does anybody knows, which IC is causing this problem?
Power Management Control IC PM8018 or
Power Management IC 338S1216 or
U2 IC 1610?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
More than likely the U2 IC that is damaged, as this chip is damaged easily with copy chargers etc.
This causes things like fast battery drain (even in airplane mode)
Overheating
And a few other symptoms.
Replace that and see what results you get. :-)
这个答案有帮助吗?
得分 1
2条评论:
where is the u2IC CHIP LOCATED, WHAT PART DO I NEED TO REPLACE
完成的
There are plenty of schematics available online, depends which iPhone.
完成的
添加一条评论
Try replacing the battery
这个答案有帮助吗?
得分 0
添加一条评论
Replace the battery is the first step to do.
Then, if still not working, should be IC or water damage.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
christian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 2,596
