跳转到主内容
Why does vertical line appear on documents using ADF as source
If I copy from the flatbed everything works fine. However if I copy or scan using the ADF, then a black vertical line appears down the center of the output document.
I wonder if there is dust or dirt in the ADF causing the line to appear, if so where can I find instructions for opening and cleaning ADF.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
9条评论
Didnt work. Cleaned the entire ADF area and nothing helped
完成的
Cleaning didnt work. The line is very straight, top to bottom, not smudged like dirt. Almost like a scratch.
完成的
cleaning did not work. is there any other solution
完成的
I have no narrow strip of glass on my scanner
完成的
IT WORKED! Cleaned the small space of my Epson WF-3530 with alcohol and cotton ball. My documents (scanned, copied, faxed) have had red streaks for over 2 years or so.
I'm excited the problem is solved and was free to resolve. :)
完成的
显示更多的4条评论
添加一条评论
4个答案
已选择的解决方案
Hi,
Here is a link to the User Manual that shows how to clean the ADF area and rollers. Scroll down to Cleaning and Transporting your Product, click to open then click on Cleaning your Product
https://files.support.epson.com/docid/cp...
这个答案有帮助吗?
得分 16
14条评论:
clean the small glass. worked!
完成的
Cleaning the small glass worked. Thank you
完成的
This is so cool!! thank you!!!
完成的
yes cleaning glass did the trick . thanks
完成的
Cleaning the narrow strip of glass on the left worked - also vacuumed the left side to remove dust. - Thanks
完成的
显示更多的9条评论
添加一条评论
This problem occurred with my Epson WP-4530 when using the ADF to scan. Epson manual says to avoid chemical when cleaning the ADF, but I could only remove the lines by using alcohol. Dry cleanig wold not work, but alcohol worked great!
这个答案有帮助吗?
得分 2
1条评论:
Thank you, thank you! I removed the lines using rubbing alcohol and a microfibre cloth on the glass, the clear plastic on the ADF, and all around the clear plastic on the ADF. Clear as a bell now!!
完成的
添加一条评论
It took spraying condensed air on the rollers to clear up my problem.
这个答案有帮助吗?
得分 0
1条评论:
Cleaned small glass panel on left. Small ink blot removed with alcohol. Removed line on feeder and feeder scan copies.
完成的
添加一条评论
Tried wiping the ‘small glass panel on left’ with a dry cloth but this didn’t help. Went at it again with a cloth dampened with alcohol screen cleaner and problem solved.
这个答案有帮助吗?
得分 0
2条评论:
Like some others who've posted, I inspected the small glass panel...subtle amounts of schmutz on it. Took some Windex and elbow grease to remove it. BUT......the effort was worth it......the two vertical black streaks on all my ADF-scanned documents were GONE !
Thanks for the suggestion.
完成的
After using microfiber with alcohol it's gone.
完成的
添加一条评论
添加你的答案
rglee46 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 73
总计 40,207
