Touch not working even after a new display
Hi, I have a Huawei mate 7 and the touch doesn't work. I've replaced the LCD, touch everything but still doesn't work. Any thoughts?
You have to put all motherboard and proximity sensor to works fine, If the mainboard is not correctly inserted dont work the touch. Please can you give me a favor? Dont put the bottom cicuit with the usb socket and tell me if switch on the mobile phone please.
这个答案有帮助吗?
I tried unplugging the bottom board where the USB is and removing the main board and plugged LCD back in then turned it on. touch still not working.
after i replace LCD,it become s view mode & cant touch..izit need put all motherboard to try?
Please tell first have you buy orgine or a clone lcd, i have hear from many users they have problems that clone dont fit or with other Problems. I have buy 3 times a clone lcd for my iPod touch and the Problem whats eher the Same problem with cable that is broken but you cant see it.
Now i have the same Problem with Huawei Mate 7 (Glas only is broken) and i have read now, that you dont can repair it with Glas only, you Must buy the Glas with digitalizer why .... When you realy make it to lose digitalzer from Glas, you Never will become it working back .
Here is a youtube Video to make ist self.
(Ist not from me and only in German )
I Hope it will help you.
Sorry for my englisch i am from Germany. When you have make it, please give a Info back. Thanks
这个答案有帮助吗?
Thank you so much for your comment, I have bought original gold LCD with frame for the Huawei Mate 7. the lcd that was on it was not repaired and the touch doesn't work. im thinking its from the Touch IC but i don't know where the Touch IC is. I have an iPhone 5S that i put a new LCD on but touch doesnt work, replaced the Touch IC and it's working fine now.
Hi, Did you fix the problem of the touch? Excuse my english, y speak spanish. I have the same problem. I've replaced the LCD and doesn't work.
no, unfortunately, I know what the issue is, though. it's from the touch IC, customer never end up coming back for it.
> The first thing you should try is to restart your phone For that, hold the Home button and Wake or Sleep button together and keep holding until the phone logo appears.
> Some phone users have found a solution by going to Settings > General > Reset > Reset all Settings. (You will have to change the wallpaper, re-enter the password, and set up touch ID, but not a single data will be removed.)
> If the above two steps fail to fix the phone Touch Screen Not Working issue, then you need to perform a Factory reset. This process will erase all the phone’s data, but I will suggest to go for set up your phone after factory reset rather than restoring from iTunes or iCloud as many users have seen that restoring the data from iCloud or iTunes brought the problem back again.
这个答案有帮助吗?
I had my phone lcd screen repaired. But it cracked just a little bit in the bottom right corner the touch worked fine but after 1 month (more or less). Did my touch go of by it self. I thought first i had got a virus but then i squeezed my phone a little bit where it was cracked and it was working again. But only for 1-10 minutes and now the touch doesn't work.
Why is this happening?
Any answers would be nice.
Thank you, for reading //Max
这个答案有帮助吗?
HUAWEI Mate 7 touch not working even when changing the new screen
my HUAWEI Mate7 not touching on the screen even when changing the new screen
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 20,013
1条评论
My Huawei Ascend G630 touch screen is not working, any idea
由 Tony Bito 完成的
