跳转到主内容
加入维修社区 - 创建账户
这是摩托罗拉于 2015 年 7 月发布的旗舰手机。它配备了一枚 2100 万像素的摄像头和一块 5.7 英寸的 IPS TFT LCD 显示屏,分辨率为 1440 x 2560(Quad HD)。型号包括 XT1570、XT1579、XT1575 和 XT1578。
Why is there a white spot on my screen?
So my father sat repeatedly on purpose on my phone, after that I noticed a white spot on the screen. It's nothing, barely visibile, but every time I see it I feel terrible. Is the screen broken or is it something else?
White spot-> those pixel are always white, on a white screen, those are noticeable because are even whiter.
Here's some photos:
open
Thanks you for your support,
Andrea
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Hi , am too using Moto x4 and I found a dot in the middle of the screen.please tell me is it a problem or what else is it .
完成的
A moving round double dots on my screen
完成的
添加一条评论
4个答案
已选择的解决方案
Based on the photos it looks like there may be something pressing against the back of the LCD, causing distortion on the display. It may go away on its own, but even if it doesn't it shouldn't spread to the rest of the screen (I don't think). If you wanted to fix it, you'd have to open it up to try to remove the object pressing against the screen, but you're likely to do more damage than good, since this is fairly minor right now.
If the problem continues check back in with us and we may be able to help you fix the spot =)
Good luck!
这个答案有帮助吗?
得分 4
8条评论:
You're absolutely right, indeed if I try to press vigorously on that spot, the screen distorts itself!
I think I'll follow your suggestion and leave it there for a while!
Thanks for the support,
Andrea
完成的
Even I have the same issue... It was on the middle of the screen on my first moto x style... Got it replaced... Then on the second one at the left to corner there is still a slight white spot if we really be able to figure that out...
完成的
If you're practice and equipped I'd say to try open it, but tell you what man, after a few weeks I don't even notice it. Just get used(ofc if you're planning to sell it, it's a different story).
完成的
Im having same issue on my new moto x style...Will it spreads eventually.. or remains there itself
完成的
No, don't worry. After a while you won't even notice it.
完成的
显示更多的3条评论
添加一条评论
I had a ASCEND MATE 7 for a while and after about two months got wild white patches on screen, sold it by the way and bought a new one. This new one even had brighter patches from the beginning!
Got this one replaced with MATE 8 by the warranty (yeah, they gave me the MATE 8 instead for whatever the reason!)
I'm now useing it for about 2 and half months and again I got white patches almost in middle and bottom of the screen! What the !&&* !?
I think this is the problem with internal batteries, as they are poor quality and after some time of use the battery's pressing against the back of the LCD ... and the whites appear
这个答案有帮助吗?
得分 1
2条评论:
I have got replaced screen dispaly of Samsung J7 2016 but after couple of days at left bottom corner of screen some greenish spots appeared and it is keeps on increasing slowly day by day, can any one has idea of whats the problem?
完成的
https://howtofixgadgets.com/how-to-fix-w... this will help you some problem can be solved using pixel fixer and some can't if the whit spot is minor adjust with it and if it's large in size or getting bigger changing screen is the only option.
完成的
添加一条评论
I have this too. After replacing my Moto X Play screen.
If I apply pressure on the ack it only distorts the screen where the white spots are. Proving Sam Lionheart's theory.
Gonna poke bout and see what's stabbing my screen in the back ;)
这个答案有帮助吗?
得分 0
添加一条评论
I had this problem with lg stylo 4. I was keeping a small flat key on the back of the phone under a protective cover. A white spot half inch diameter appeared in the center. I understood what was happening when some people talked about pressure on the phone. When I opened the cover and removed the key the spot disappeared progressively. Initially when the key was put under the phone's protective cover it stayed there (I don't lock my room) and I didn't see the white spot at the time. It appeared a few days later and I failed to relate its occurrence to the key that was pressing on the device from the back.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew De 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 34
总计 98,423
