跳转到主内容
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
Why won't my Galaxy Note 3 Power On?
I have a Note 3 N9005 that ran out of charge and died. Now it is almost completely dead even after charging continuously for 2 nights. I've already tried another battery. The screen just stays black like it's powered off and there's no charging or other LEDs (touch buttons at the bottom stay dark) but the phone vibrates only once after plugging in or pushing the power button. To get it to vibrate again, a power drain needs to be done. The battery is still charging because it gets warm when plugged in.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Hi iMedic, thanks for replying. I have already tried that. There's just nothing on the screen at all after the initial short vibration of plugging in or powering on.
完成的
添加一条评论
2个答案
已选择的解决方案
I just learned about this. Try removing the battery, plugging in the charger, let it charge for a little bit, then putting the battery in, while its still on the charger. Hope that fixes the problem
这个答案有帮助吗?
得分 2
2条评论:
Sorry, just realized that I had to post the comment here, Hi iMedic, thanks for replying. I have already tried that. There's just nothing on the screen at all after the initial short vibration of plugging in or powering on.
完成的
Could try a hard reset. But you'd lose all your data. I'm starting to wonder if your phone is on, you just can visually see anything
完成的
添加一条评论
Remove back cover
Remove all screws from mid frame
Carefully remove mid frame
On the right upper side (about even height with volume keys on side of frame) you'll see a gold looking cable connector (is the one that connects the LCD and digitizer)
Make sure it's snuggly connected.... this often pops out when dropped.
If your LCD display looks okay, phone vibrates and lights appear, this may be your problem.
这个答案有帮助吗?
得分 2
1条评论:
Thank you, Holly!!!!!!!!!!!!!!!!!!!!!!!!! It worked!!!!!!!! Go eat some carbs openly!
完成的
添加一条评论
添加你的答案
SMN9005 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 7,513
