跳转到主内容
The LN46A530 has a 46" display, combined with SRS TruSurround XT. The PC input allows this display to double as a 46" computer monitor
71 个问题 查看全部
HDMI Problems and connecting
'''bold textMy HDMI cable attach from my notebook to the HDMI port on my Television is not working as it should be. When attach, all I am getting is the icons on the taskbar but none on the desktop and a different screensaver, I have tried unplug the television for 10 min, plug it back on, reconnect the hdmi cable, I usually use HDMI2, that did'nt work also the other HDMI port.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
Hi,
Can you try a different device on the HDMI inputs of your TV, e.g a dvd player or anything with a HDMI output? This is to isolate the problem to either the TV or your notebook. Also if you can try a different HDMI cable, again to eliminate possibilities.
完成的
添加一条评论
1个答案
Did you use separate screen option? Or duplicate?
Is this the first time you used an Hdmi?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Roderick Maloney 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 174
