跳转到主内容
加入维修社区 - 创建账户
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
ipad mini error 4013
Hi guis i have a promlem. my ipad mini have error 4013. somebody can help me???
pleade
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Try a different USB cable. The iPhone error 4013 can be caused by a hardware problem. It's possible that the iOS device is disconnecting from iTunes, or iTunes can't communicate correctly with the device, because the cable connecting the device to the computer is faulty.
Regards,
Will
完成的
添加一条评论
2个答案
已选择的解决方案
Error 4013 is usually a usb problem.
Use the USB cable that came with your device, or a different Apple USB cable.
Plug your cable into a different USB port directly on your computer. Don't plug it into your keyboard.
Try a different computer.
Solve other issues with the USB connection, then with your security software.
这个答案有帮助吗?
得分 2
7条评论:
i have try 3 cable and 2 cpmputers
完成的
Ok. Are they aftermarket ones?
完成的
One original and two aftermarket. But i have resto Red some iphone with this Cable
完成的
Don't trust aftermarket cables. Also try the other things I said
完成的
I tried everything but nothing. It could be the USB connector?
完成的
显示更多的2条评论
添加一条评论
4013 is NAND error. try replacing front camera
这个答案有帮助吗?
得分 1
3条评论:
how is the camera related to the NAND?
完成的
A faulty front camera can stop the device restoring.
完成的
forgot how pesky apple is with EVERYTHING. upvote. my apology
完成的
添加一条评论
添加你的答案
Pasquale 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 33
总计 5,774
