跳转到主内容
Released on October 1, 2013 the BLU Studio 5.5 is an unlocked Android smartphone with two model types being the D600 (single SIM) or D610 (dual SIM).
82 个问题 查看全部
Battery and Head Phone issue.
Hello. I've been dealing with this issue for about 2 weeks. When I'm using my phone without the adapter for only 2mins the battery goes from 100%-1% in under 5 mins or just completely dies. Second issue when I plug in my Ear Buds I can only hear from one side. Ive tried the same Ear buds with another phone and it works perfectly fine. What can you or I do at this point.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
With your battery issue, it seems as if your battery fails to hold a charge and probably needs to be replaced. How old is the battery? Even rechargeable batteries have a life span.
With your earbud problem it may be that the earphone socket in your phone is faulty. The connecting spring inside the actual socket may have lost tension or the socket may have come loose from the board.
To test which connection is actually faulty, plug your earbuds into a working phone socket. Take a note of which is the left earbud. Mark it somehow so that you you know which one it is. Plug the earbuds into your phone and make sure the left earbud is actually in the left ear. Now which side gives no sound?
Here is a picture which shows the connections for a plug
If it is the left earbud that is not working, have you fully inserted the plug? The plug should go right in until the holder touches the phone case
If it is and it is still not working or if it is the right earbud, here is a link which shows (not very well, also it is in Spanish but the video is self explanatory) how to dis-assemble a Blu Studio 5.0 (not your model I know but perhaps close enough to be of some help) so that you can gain access to the headphone socket. At 2:36 minutes into the video the headphone socket can be seen on the top edge of the phone (as viewed) from the right side (under the 'S'). You can then determine if it is loose and if not if it needs to be replaced.
https://www.youtube.com/watch?v=4n9K2EKp...
If you do not have the tools or the skills to repair the socket, take it to a professional phone repair service to be fixed.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Vinay Sewkaransing 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 82
