跳转到主内容
Released on October 1, 2013 the BLU Studio 5.5 is an unlocked Android smartphone with two model types being the D600 (single SIM) or D610 (dual SIM).
Why can't I get out of safe mode?
I put my phone in safe mode to uninstall an app, and now I cannot shut it down to start it up the right way. I never get my Home screen, and have removed the battery several times as was suggested, but that doesn't work. Any ideas out there?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
i have the same problem. tried everything. just a terrible phone.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Try the following.
If you can turn off the phone, skip the part about removing the battery.
Take out the battery for a few minutes, then put the battery back in, press and hold the volume up button then press the power button and continue to hold the volume up button until your phone turns completely on.
这个答案有帮助吗?
得分 2
4条评论:
Thank you for your reply- to my question, however that sis not work. How frustrating ..... The phone repeats the initial reboot, but I never get the Home screen.....
完成的
Hello again, I held the volume up button and start button together again, and did eventually get a menu with a reboot option, but Highlighting that option and then pressing the enter key, as suggested, does not do anything....
完成的
Hi,
Try the 'WIPE DATA FACTORY RESET' option. This will put you phone back to factory condition. Like when you first bought it. It will erase all the data that YOU put in it but at least it will be like new again.
完成的
This BLu mobile phone doesnt turnoff safe mode by restart,reboot,factory reset,wipe cache or any others means .Why the solution to exit safe mode on my device, BLu mobile G5?
完成的
添加一条评论
添加你的答案
lisajanisse 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 1,755
