跳转到主内容
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
How to repair a loose analogstick?
so right now my xbox 360 analog sticks are all suffering from the same problem is that the analog stick is loose and wont fix its self back to center it makes it really annoying in game that my character is moving ever so slightly off in to a direction.
so my question is how can i fix a the loose analog stick?
with out any solder or having to buy a new controller.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 10
1条评论
Enciende mi control de xbox 360 pero no se conecta por Bluetooth
完成的
添加一条评论
6个答案
已选择的解决方案
The drift is a very common problem but infortunately no real fix. Cosmetic issues are really the only thing that is cost effective to be fixed. You can get a used controller for like $20.00 to $25.00.
这个答案有帮助吗?
得分 5
1条评论:
thanks, i guess i will have to look for some old controllers
完成的
添加一条评论
For about half the price of buying a used controller here is a firstaid/rebuild kit for it:
http://secure.llamma.com/catalog/product...
这个答案有帮助吗?
得分 3
添加一条评论
You need to change the potentiometer. You can get a potentiometer in good condition, by an original xbox control.
这个答案有帮助吗?
得分 1
1条评论:
My hole Joystick is broken off
完成的
添加一条评论
Its always good to have spare joypads around, a 10 bucks thingy usually fits the need, also old ps1 dualshocks seem to have very durable parts
its as simple as desoldering the sticks and put in the harvested on and solder it back
most analog sticks except for ps3 and nontendo ones are the same
and the pcb of a dissected pc joypad can be used to make old joysticks like sidewinder or even the old amiga thingies to work with usb
这个答案有帮助吗?
得分 0
添加一条评论
If it works fine, but is just loose then follow the repair guide to take it apart and put a DAB of silicone on under the stick. This way you can still take it off it you want to change them out later. That's what I did and it works perfect. Hope that helps!
这个答案有帮助吗?
得分 0
添加一条评论
can i see bord of controller's charger
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gorillahouse 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 25
过去 30 天: 117
总计 90,802
