跳转到主内容
The Keurig Mini B-31 is a compact single cup hot beverage brewer that uses Keurig's K-cup dispensing system.
HELP I dropped my needle into my Keurig Mini Reservoir!
I was doing the "needle trick" and my needle fell into the Keurig. When I shook it around I can see that it is in the reservoir! :(
Does anyone know how I could get it out? OR should I not be worried about it? I am scared it will rust and get into the water.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Get tweezers and take it out.
这个答案有帮助吗?
得分 0
5条评论:
That's the problem, I don't know how to get into the water reservoir. It's a Keurig Mini so it doesn't have that open reservoir on the left like some of the newer versions. It's sealed off.
完成的
Tip it upside down and shake it
完成的
I don't think you understand. The water reservoir is sealed off. There is no open top for the needle to "just fall out"...that's what my entire problem is!
完成的
Ohh, ok.
Well, i do not know then, sorry.
完成的
I did the same thing. Only I dropped one of the round plastic washers into the reservoir. I'm doing a complete tear-down now and don't know what I'm doing. It"ll be a miracle if I get this thing back together.
完成的
添加一条评论
添加你的答案
lissiekmi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 344
