跳转到主内容
所有制造商和服务提供商的手机的维修指南和拆解信息,包括苹果 iPhone 和三星 Galaxy 系列。 获取您亲手维修手机所需的一切资料。
73633 个问题 查看全部
Straightalk phone keeps saying Mobile network state disconnected
Ok so my phone wont work it its straightalk and i havnt refilled in a while and i just bought a new sim card and use the $40 card to refill it. I noticed that i also dont have a phone number when i go into settings. Im not sure what to do if anybody had the same problem and figured out how to fix it please let me know I really need help w/ this ..thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Mine was the same...re inserted Sim restarted phone turned data and wifi off and on and nothing....go turn airplane mode on for 30+ seconds and then turn it back off with your data turned on and your wifi also turned off
完成的
添加一条评论
4个答案
已选择的解决方案
Hi
Have you activated the service?
Here is a link to the Straightalk website.
https://www.straighttalk.com/wps/portal/...
这个答案有帮助吗?
得分 3
4条评论:
I have service is this my phone or something they have done I'm family mobile it has kept going from emergency calls to network and then I discovered it's disconnected too
完成的
Please Please Help Me!! I'm not sure why but my screen an everything I click on. Is like in NEGITIVE MODE I MEAN EVERYTHING I TRY AN LOOK AT LOOKS LIKE A NEGITIVE FROM AN PHOTO. AN SOME SCREENS ARE JUST BLACK IM NOT ABLE. TO SEE ANYTGING IVE BEEN DEALING WITH THIS FOR AWHILE BECAUSE I DON'T WANT TO RESET MY PHONE
完成的
Had the same problem. I have a LG Fiesta 2. Had to change APN to
TRACFONE.VZWENTP.
完成的
Thanks it works.
完成的
添加一条评论
Hi,
You can fix it with the carrier settings or reset the network, here’s how to fix it:
https://grouphowto.com/mobile-network-st...
这个答案有帮助吗?
得分 1
2条评论:
Thanks, it work for me. Love the instructions
完成的
@Abdel Lamrani You are very welcome
完成的
添加一条评论
If you are new to this and don’t about the issue, then you must read this part. Otherwise, you can skip it. The error called “Mobile Network State Disconnected” it’s about the signal issue of an Android phone, often it happens because of the network sim if you have an only 3G sim and the phone is trying to connect to the 4G network.
Diagnose the mobile network state disconnected Error
  • Method 1: Restart the device
  • Method 2: Check for Networks
  • Method 3: Check For the Reception
  • Method 4: Check router settings
  • How to fix mobile network state disconnected Error?
  • Method 1: Change Mobile Network mode(3G/4G)
  • Method 2: Reset Network(Sprint, AT & T)
  • Method 3: Deactivate The WIFI Connection
  • Method 4: Reset The APN Settings
Source: https://fixyourandroid.com/fix/mobile-ne...
这个答案有帮助吗?
得分 0
添加一条评论
Want customer service please
Update (10/29/2022)
Yes need customer service
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Average 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 35
过去 30 天: 211
总计 24,884
