跳转到主内容
Repair guides and troubleshooting for the Acer Aspire V5, a series of laptops on the Windows OS by Acer.
132 个问题 查看全部
will not charge...no power
the laptop has lost all power and will not work even with charger plugged in to power source.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Facing the same problem for the third time and this time it is out of warrenty. Actually, the power ICs are burned and god knows why its happening again and
完成的
Hi @ Arsh Goyal,
Have you checked the output from the charger to make sure that is within specs i.e. 19VDC?
完成的
添加一条评论
1个答案
最有帮助的答案
Hello,
i have same problem on same laptop. mine was old one month, just stoped working! I tryed new charger, new battery, all trick's from internet and it didnt work. I have take him to waranty and get al new internals (MBO; HDD, RAM). My advice if is under waranty, use it!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
hope reese 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 644
