跳转到主内容
Sony Xperia Z3 Compact released in Sep. 2014.
Why is my display blinking?
Hi everyone!
I've broken my Z3C back glass and lower speaker. Got spare parts from eBay, then replaced it following your instructions.
As I've fixed many iPhones and other phones I consider myself experienced in it and this replacement was one of the easiest ones.
Anyways, after putting everything together I started it up and the display was a bit dimmed in the right bottom corner and blinks when I push the back glass. Even just a slight force is enough for it to blink.
Can't find any relevant answers on the net, so I am turning to you with this Q.
Thanks everybody a lot for the tips!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Sometimes the screen flickering problem can be fixed by Sony official software, but if there’s no official solution for it, you can also try reconnect the screen flex cable, cause the flex cable may be loosen when accidentally drop or hit.
However, if software and flex cable reconnection can not fix the screen problem, then you should turn to the hardware solution: change a new screen.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
odehnalr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,034
