跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
I cracked my phone screen but still on and its blacked out?
cracked it on Sunday and I was hopping to get it fix around this week and I was listening to music going to lunch and the screen just shut down. Once I was in class my phone ringed but couldn't answer because of the screen can I get the screen fix or will I have to replace the phone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 21
6条评论
I have the same problem currently. Will they replace my phone though? Or will they call it busted, if this can be solved let me know. Please. I have an IPhone 5S.
完成的
Can i have it then
完成的
if your screen is cracked and its not turning on or its black you can fix your screen its the screen back wire in the back of the phone that ripped that made your phone turn all black all u have to do is get a new screen put it on your phone and boom it turns on and the screen not black anymore. hope this help u!
完成的
Or! you can plus in your headset, and use the toggle buttons to answer calls... just can't text anybody.
完成的
i have the same problem, like before my phone is still on and i get notifications but the screen is black and i dont know how to fix it
完成的
显示更多的1条评论
添加一条评论
4个答案
已选择的解决方案
I think you need a new lcd :)
这个答案有帮助吗?
得分 4
添加一条评论
Try to do a hard reset on your phone.
Hold the power and home button for around 7 to 10 seconds. This should reboot the device. Let go when you see the Apple logo. Your phone should be fine now.
If not, let me know and Ill suggest other steps.
这个答案有帮助吗?
得分 3
7条评论:
will it restart the phone
完成的
It will restart the phone.
完成的
More than likely the lcd is bad and needs to be replaced. I have seen a hard reset fix this issue sometimes.
完成的
my screen come on but it send me message but i cant see them and than the screen go back to black out
完成的
I tried this and it showed something else like a gray thing and gray lines and i can barely see the apple than it goes back to black and it did this over and over again
完成的
显示更多的2条评论
添加一条评论
Yup, you'll have to replace a new LCD, it costs about $100 to get a replacement online. Here are the part and tutorial guide 's links you may need:
Part: http://www.etradesupply.com/apple-iphone...
Tutorial: iPhone 6 LCD屏幕面板的更换
这个答案有帮助吗?
得分 3
添加一条评论
not yet , You can used it as usual
But if you want to replace a new original screen,Here are the part may you need
iPhone 6 screen:http://www.hcqs.cc/iphone-6-lcd/iphone-6...
这个答案有帮助吗?
得分 1
1条评论:
I cracked my screen and it doesn’t show anything but Ik it still turns on Bc my home button clicks (I have a 7 plus) another thing is when it cracked I asked someone to call me to see if I can hear it and I couldn’t
完成的
添加一条评论
添加你的答案
jesusa mejia 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 37
过去 30 天: 153
总计 78,030
