跳转到主内容
加入维修社区 - 创建账户
型号 A1418 / 2012 年末 / 2.7 & 2.9 GHz Core i5 或 3.1 GHz Core i7 处理器
No Power - won't turn on
My computer just shut down and won't power back on. Won't do anything. It is like it isn't even plugged in. I have tried a different power cord. I tried holding the power button. I have unplugged everything from the usb ports.
I have opened up the computer - I am wondering where the diagnostic led lights are. I am wondering if it is the power supply board - it does look like some wiring melted - although its not black or burnt...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
The diagnostic LEDs are to the right of the RAM slots.
完成的
Could be a bad power supply unit
完成的
添加一条评论
3个答案
已选择的解决方案
Be sure to discharge the big capacitors and handle it with one hand. I may be mistaken, but that looks like where the transformer bridges from the AC side to DC side. It will have very high voltage there. If that's exposed wire in the pic then it is likely indicating a problem. The end of one wire looks yellowish too, as if it may have been hot. All of your symptoms point to a bad power supply. About 70% of the time I see these it's the Power Supply, so I'd definitely put my money there.
这个答案有帮助吗?
得分 2
添加一条评论
The diagnostic lights are to the right of the RAM slots.
这个答案有帮助吗?
得分 2
添加一条评论
The diagnostic lights are under the RAM slots. See picture
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lesli KeepSimple 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 1,840
