跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1149 个问题 查看全部
Touch function does not work on the bottom of the screen, why?
I have replaced the part and the installation proved to be easier than I though, however once I turned the phone back on, the touch function does not work at the bottom of the screen, I cannot hit the space bar and the lower letters...nothing...what do I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
4个答案
最有帮助的答案
If the part that you just replaced is the digitizer panel
that means you might have faulty digitizer panel.
But before jumping to conclusions,i would open the phone again,
and i would disconect the cables #1 #2 and #3,and i would take out the lcd+digitizer panel assembly and set it aside.
Then i would check with a magnifier mirror,the contacts on the flat cable
#1 which is the one responsible for the digitizer panel and then i would take one of those aerosol spray cans,used for cleaning of computer keyboards and i would blow a few jets of air in the conector where the flat cable #1 goes in.That's the special one that you have to lift a small
piece of him to be able to put the cable in and then you have to slide it back down to secure the cable in place.
It might be a speck of dust or something small inside there that doesn't allow a good contact and then you don't have the bottom of the screen working,like you do now. Good luck.
这个答案有帮助吗?
得分 2
添加一条评论
I believe you have a faulty piece of hardware. Maybe it was messed up during transit, or maybe you just bought a faulty one.
这个答案有帮助吗?
得分 0
添加一条评论
I had this same problem. Multiple restores, cleaned and reseated contacts, to no avail. I decided to try downgrading to 3.1.3, and after downloading an ipsw, trying to restore with it and getting an error, I restored to 4.2.1 without issue, bottom working perfectly. I'm not offering this as a tutorial as I'm mainly an Android guy, but it definitely worked for me.
Cheers,
tabormeister
这个答案有帮助吗?
得分 0
添加一条评论
I have a nexus 7 and when I type it jumps to the next letter
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
stepharbour 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 28,226
